Problem when converting a cart with 2 products on order by code, just add 1
gusman126
I have developed a module that reads the data and adds the information to a cart
EDITO to clarify:
This cart is generated with a php file, it has been called from a CRON that reads the information by a call "curl", it is not generating the cart while visiting or using the web page.
Similar to if you read the data from a CSV -> cart -> Order
Add the new customer
 $customer = new CustomerCore();
Add the address
$address_shipping = new Address();
generate the cart
 $cart = new Cart();
Add products
foreach ($productos as $producto){
    $cart->updateQty($qty, $id_product, $attr);
It update and save, and until here everything ok, I check the cart and it is added with all products 1,2,3 or more
Valid the order associating it with a payment module and generate the order
$pago->validateOrder($id_cart, $order_status, $total_products, 'Pagado', NULL, array(), (int)$id_currency, false, $customer->secure_key);
$order = new Order($pago->currentOrder);
$order->setCurrentState($order_status);
$order->save();
And here the problem,
The order only stays with 1 product, does not add the products of the cart to the order, always 1, have the cart 1,2 or more
Solution?
Edited by gusman126 (see edit history)
