Adeniyi2010 Posted January 6, 2011 Share Posted January 6, 2011 My product comment module is showing this message on ALL the tabs on my product page instead of only under the Comment Tab:"No customer comments for the moment.Only registered users can post a new comment."In addition to this, my Product Category Module is showing under the Product Comment Tab too. I have tried all I knew but I cannot just fix this. Any help will be appreciated.Niyi Link to comment Share on other sites More sharing options...
PrestaShopDeveloper Posted January 6, 2011 Share Posted January 6, 2011 Do you use the default theme and what PS version do you have? Link to comment Share on other sites More sharing options...
Adeniyi2010 Posted January 6, 2011 Author Share Posted January 6, 2011 Do you use the default theme and what PS version do you have? HiI am not using the default theme. I am using the Matrice theme. I also use Prestashop version 1.3.5. Thanks for your response! Link to comment Share on other sites More sharing options...
PrestaShopDeveloper Posted January 6, 2011 Share Posted January 6, 2011 This theme does not support product comments by default.The productcommentes template must be overriden, to support the theme. As far as I can see, you should see the "tab name". Also, there's already element with ID=idTab5 in product.tpl - this is the ID used at productcomments module as well.Override the productcomments.tpl in the theme: copy it to themes/matrice/modules/productcomments/productcomments.tpl and change the idTab5 at the template. You'll need to make the module template fit the "matrice" designl, since this is not initially supported. See the hook.gif at the theme archive to see which modules are supported by the theme. Link to comment Share on other sites More sharing options...
Adeniyi2010 Posted January 6, 2011 Author Share Posted January 6, 2011 This theme does not support product comments by default.The productcommentes template must be overriden, to support the theme. As far as I can see, you should see the "tab name". Also, there's already element with ID=idTab5 in product.tpl - this is the ID used at productcomments module as well.Override the productcomments.tpl in the theme: copy it to themes/matrice/modules/productcomments/productcomments.tpl and change the idTab5 at the template. You'll need to make the module template fit the "matrice" designl, since this is not initially supported. See the hook.gif at the theme archive to see which modules are supported by the theme. HelloI cannot get the comment to work well. "No customer comments for the moment. Only registered users can post a new comment" still appears on all the tabs. I changed the idTab5 in productcomments.tpl to another number but it still shows the same way.I think I was a bit confused too on the suggestions you gave. Please see the attached picture. The circled texts showed on each of the tabs. Under Comments itself, products categories (We Have Also) are displayed. Please help. Link to comment Share on other sites More sharing options...
Adeniyi2010 Posted January 7, 2011 Author Share Posted January 7, 2011 I finally resolved this on my own. View solution Here! Thanks to UltraWebDev for the lead!Cheers Link to comment Share on other sites More sharing options...
