Mowerman41 Posted September 6, 2010 Share Posted September 6, 2010 I need to find out would it be hard to build a site to match this type of business ? Small Engine parts store need advice since im new to prestashop Link to comment Share on other sites More sharing options...
likeminded Posted September 6, 2010 Share Posted September 6, 2010 Generally pretty easy - you can theme presta to suit any type of business really - you could check out some of the themes that are pre made as a starting point Link to comment Share on other sites More sharing options...
Mowerman41 Posted September 6, 2010 Author Share Posted September 6, 2010 Where do i find these themes and are they free ? Link to comment Share on other sites More sharing options...
likeminded Posted September 6, 2010 Share Posted September 6, 2010 Try prestastore, here one that could workhttp://www.prestastore.com/templates-prestashop/483-templates-prestashop-race.html Link to comment Share on other sites More sharing options...
Mowerman41 Posted September 6, 2010 Author Share Posted September 6, 2010 that was fast reply you guys are on the ball here what im looking for is somelike this competitors site mowpart.com is that possible with prestashop ? Link to comment Share on other sites More sharing options...
likeminded Posted September 6, 2010 Share Posted September 6, 2010 With a little bit of work you could make a better looking site! A little bit of searching both the forum and google should cover all your questions Link to comment Share on other sites More sharing options...
Mowerman41 Posted September 6, 2010 Author Share Posted September 6, 2010 Only one issue i am not a website designer Link to comment Share on other sites More sharing options...
likeminded Posted September 6, 2010 Share Posted September 6, 2010 Do you have an existing website? or web host that you use? Most of what you need would be modules that you install/activate. Failing that you could hire one to do the work for you Link to comment Share on other sites More sharing options...
