How do I add products to specials and Top Sellers. HELP!
horns
To add a product to the specials block, you must edit the product you want to be on special, then give it a reduction amount or percentage. The top sellers are automatically created based on how many times the product has sold on your website. It is not possible to choose which products are top sellers, unless you modify the ps_product_sale table of your database and find the product ID and increase the value of the sale_nbr column for that row.
  • 1 year later...
Hi nc i didn't get you where to give reduction amount or percentage for adding a product to special block.
Can you provide option names to give percentage?
Thank you.
Hi venkatesh,
I answered that question for you over on your other post here. Please let me know if that works for you.
-Mike
Yes Mike its working. Thanks for your help.
  • 1 year later...
