jbaranello Posted April 17, 2014 Share Posted April 17, 2014 Hi, First want to say that this software is great and Ive had a lot of fun playing with it. Now I have a theme I purchased and it seems that the developer has now decided to remove it from the add-on store, maybe due to my constant emails concerning some issues which they never responded to?? Needless to say I still paid for the theme and got most of the issues resolved on my own. There are only a few issues left, two of which I am at my wits end on trying to get it to work. So was wondering if anyone had any ideas? 1 - In the footer there is a block (included with theme) that shows featured products. Now the title is there, the block is showing (I think) but no products being displayed? 2 - On my homepage the New Products block is hidden on loading the page but when I click on New Arrivals it loads the new products. How do I get it to show the block on loading the page?? If you need anymore info let me know. Thank you Jason Link to comment Share on other sites More sharing options...
Draygon Posted April 17, 2014 Share Posted April 17, 2014 JB, In order for the featured products to show on your landing page via the module, you must add the products you want shown there to the "Home" category under the associations tab. I'll see if I can find some info on the other issue. Link to comment Share on other sites More sharing options...
jbaranello Posted April 17, 2014 Author Share Posted April 17, 2014 Hi Draygon, Thanks for the info, it seems your solution fixed BOTH problems. As the New Arrivals section also includes Featured Products (not in the footer) as soon as I included a few products within my home category, a new tab came up next to New Arrivals (Featured Products) and that seemed to fix the issue of it always being hidden when page loads. Thanks again. Jason Link to comment Share on other sites More sharing options...
jbaranello Posted April 17, 2014 Author Share Posted April 17, 2014 Hi Draygon, One more little question, is there anyway to set the New Arrivals Tab as the default tab that shows when the homepage loads? Thank you Jason Link to comment Share on other sites More sharing options...
vekia Posted April 17, 2014 Share Posted April 17, 2014 Hi Draygon, One more little question, is there anyway to set the New Arrivals Tab as the default tab that shows when the homepage loads? Thank you Jason go to modules > positions and search for displayHomeTab move the new products block to the top of this modules list, like i show below: Link to comment Share on other sites More sharing options...
jbaranello Posted April 18, 2014 Author Share Posted April 18, 2014 Hi vekia, Thanks again for the help. Unfortunately it doesnt work. The featured products is still the first tab on my hompage. Any other ideas for getting New Arrivals to be the default?? Also I seem to be having an issue importing images (since I upgraded to 1.6.0.6) via CSV WHEN they are located on my hosted server. I created another folder called images in my root Prestashop install and that where all my images are. The images are at 644 and the folders at 755 and my root PS install folder at 750 permissions. Images that had a URL that was not on my server (suppliers site) were imported just fine. Wut do you think this could be? Again thanks for all the help. Jason Link to comment Share on other sites More sharing options...
jbaranello Posted April 18, 2014 Author Share Posted April 18, 2014 Forgot to mention above that the theme I am using is not the default theme but a purchased theme. Thank you Jason Link to comment Share on other sites More sharing options...
vekia Posted April 19, 2014 Share Posted April 19, 2014 in default bootstrap template it works. so i bet that problem can be related to your theme, perhaps it uses different way to display these tabs as long as i will not be able to see it live - it will be almost impossible to help Link to comment Share on other sites More sharing options...
jbaranello Posted April 19, 2014 Author Share Posted April 19, 2014 Hey vekia, Thanks again for your help. Here is the url: http://www.secdistribution.ca Thank you and let me know. Jason Link to comment Share on other sites More sharing options...
vekia Posted April 19, 2014 Share Posted April 19, 2014 it looks like non-default solution. you've got module named tabs_deal ? or something similar to it? Link to comment Share on other sites More sharing options...
jbaranello Posted April 19, 2014 Author Share Posted April 19, 2014 Is there anyway I can set New Arrivals to be the first tab? Thanks Jason Link to comment Share on other sites More sharing options...
jbaranello Posted April 20, 2014 Author Share Posted April 20, 2014 Hi vekia, I think I found the module .tpl file to fix this. I tried a few things but can't get it to set the New Arrivals as the default tab. I have attached the .tpl .php file for this module. Any ideas?? Thank you Jason blockhomeproductslide.php.zip Link to comment Share on other sites More sharing options...
jbaranello Posted April 23, 2014 Author Share Posted April 23, 2014 Any ideas anyone? Thanks Jason Link to comment Share on other sites More sharing options...
jbaranello Posted April 25, 2014 Author Share Posted April 25, 2014 bump Link to comment Share on other sites More sharing options...
steve_c Posted April 25, 2014 Share Posted April 25, 2014 My page is currently experiencing this problem here Link to comment Share on other sites More sharing options...
steve_c Posted April 26, 2014 Share Posted April 26, 2014 My page is again experiencing this problem. It's intermittent and definitely a bug. Seems to be solved by clearing cache. Link to comment Share on other sites More sharing options...
jbaranello Posted April 26, 2014 Author Share Posted April 26, 2014 Is your problem completely solved? Or does it come back? Thanks Jason Link to comment Share on other sites More sharing options...
steve_c Posted April 27, 2014 Share Posted April 27, 2014 Hi Jason No it comes back every day. I have to keep clearing the cache. Link to comment Share on other sites More sharing options...
jbaranello Posted April 27, 2014 Author Share Posted April 27, 2014 Wow that is a weird problem. What did you do to get the New Arrivals tab to be the default? Thanks Jason Link to comment Share on other sites More sharing options...
