jxdyzwh Posted January 13, 2014 Share Posted January 13, 2014 how to difference click event(list click and edit click) Link to comment Share on other sites More sharing options...
NemoPS Posted January 13, 2014 Share Posted January 13, 2014 Can you specify your needs? You want to know how to build the 2 links? They are simply linking to different pages. The first one has viewcustomer in the url, the second one has updatecustomer Link to comment Share on other sites More sharing options...
vekia Posted January 13, 2014 Share Posted January 13, 2014 this is 1.4? this part of shop has got onclick="document.location=......") function so you have to modify template file, or php file (depending on version you use) Link to comment Share on other sites More sharing options...
NemoPS Posted January 13, 2014 Share Posted January 13, 2014 It seems 1.5 to me...no? Link to comment Share on other sites More sharing options...
jxdyzwh Posted January 14, 2014 Author Share Posted January 14, 2014 ps version 1.5.4,i am already solve the question,is use $this->addRowAction('view') method achieve Link to comment Share on other sites More sharing options...
NemoPS Posted January 14, 2014 Share Posted January 14, 2014 Great to know, I marked the topic as solved! Link to comment Share on other sites More sharing options...
