Help! Save and Stay doesnt works - Products does not gets updated
Hi Fellow members,
I need your help in resolving a strange issue on my portal : www.acmahabazaar.com
I can not get the products edited from the back end.
While I try to edit any of the products, they don`t seem to reflect the edits applied, instead they retain their original values.
For example
I tryto edit this products price :
http://screencast.com/t/2rPfBXFD6  >> http://screencast.com/t/do62OJysCg1S
and while after entering the values http://screencast.com/t/s3sxVXkxFN and pressing "save and stay" I get redirected to the catalog list page  http://screencast.com/t/XB9bXwetCD
and I dont see the changes I have made to product price being applied
Also,
I don`t see any confirmation message/Error message and the same thing happens if the product is directly saved instead of "save and stay "
Help Much appreciated!!
-Seomaster
  • 3 weeks later...
  • 1 month later...
It shouldn't happen. Have you used any other or external module to update your product details ? What I recommend you to update your shop to the latest version or re create the database. May not solve the issue.
Have a look on you "ps_product" table what is the price there ?
Delete it and update it. Or simply use this module I've attached. Hope it may help you.
quickupdate.zipFetching info...
