cafetango Posted December 1, 2013 Share Posted December 1, 2013 (edited) Hello, I am having problems with the layered navigation module with my multistore enabled installation. Stock Status showed "Unavailable" always I set up a group of stores and set "shared available quantities to sell" to yes. However the Availability option only showed "Not Available" option. (see screen-shot-1.png or go to http://www.felizprimavera.com/gb/5-women-s-shoes) Layered Navigation Module: Filter disappeared after update Created a filter for stores under same group. Then went back to edit (see screen-shot-2.png) Save the changes Filter disappeared from list (see screen-shot-3.png) Filter shared between stores only showed up in first store Set up a filter which applied to stores in a group (see screen-shot-4.png) Layered navigation module was set to show in the left column for all stores (see screen-shot-5.png) Navigation block only showed for first store (http://www.felizprimavera.com/gb/5-women-s-shoes) and not for the second store (http://www.felizprimavera.com/MadamePivot/gb/5-women-s-shoes) Would someone please help identifying the cause of the problems? I am at my wit's end in resolving the issue given the sparse documentation on the layered navigation module and the multistore feature. Many thanks, Cha ------------------ My installation is configured as follows: Server information Server information: Linux #1 SMP Thu May 16 05:38:49 EDT 2013 x86_64 Server software version: Apache PHP version: 5.3.26 Memory limit: 200M Max execution time: 120 Database information MySQL version: 5.5.32-percona-sure1-log MySQL engine: InnoDB Tables prefix: ps_ Store information PrestaShop version: 1.5.6.1 Shop URL: http://www.felizprimavera.com/ Current theme in use: perlamoda Mail configuration Mail method: You are using the PHP mail function. Your information Your web browser: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/31.0.1650.57 Safari/537.36 Edited December 1, 2013 by cafetango (see edit history) Link to comment Share on other sites More sharing options...
SylvainG Posted December 3, 2013 Share Posted December 3, 2013 Hello, Filter shared between stores only showed up in first store I've noticed that hooks are managed on per store basis. did you check that layered navigation was correctly hooked in all stores? Have you run a reindexation after the creation of the new filter? Link to comment Share on other sites More sharing options...
Alexgaw Posted January 12, 2014 Share Posted January 12, 2014 I have same issue. Attributes filters shown on store one but not in store 2. In DB layered_product_attribute table only shop_id 1 attributes are indexed. This module does not seam to be multi store compatible. Cannot create unique templates per store. I am using versino 1.10.0 Please help. This is a critical module that must work correctly Link to comment Share on other sites More sharing options...
jadeitelibraswallow Posted May 8, 2014 Share Posted May 8, 2014 I made a quick workaround for this issue http://www.prestashop.com/forums/topic/329196-solved-multistore-problem-blocklayered-module/?p=1665070 Link to comment Share on other sites More sharing options...
shaun_imakr Posted September 17, 2014 Share Posted September 17, 2014 Since this workaround doesn't work, is there anybody who has found a solution for this issue? Link to comment Share on other sites More sharing options...
