neoset Posted October 22, 2013 Share Posted October 22, 2013 First of all sorry for my English.Today almost all websites have the valuation with stars in their products, but has no default Prestashop has this system and is much needed for sales and customer trust.What I need is a module or a few lines of code that allow me to teach the stars of valuation and number of comments in Featured Products, Products List and under the overall product. I think it's easy because it only reflect the average degree laying on the Product page and the number of comments.I think this is very necessary and important for sales in Prestashop and should be the default in Product Reviews, the customer to see the average valuation of the products are much more encouraged to buy. A greeting and thank you very much. Link to comment Share on other sites More sharing options...
Paulito Posted October 22, 2013 Share Posted October 22, 2013 Good morning Have a look at this tutorial to see if it helps you a little http://nemops.com/prestashop-product-rating-product-list/ Paul Link to comment Share on other sites More sharing options...
neoset Posted October 22, 2013 Author Share Posted October 22, 2013 Good morning Have a look at this tutorial to see if it helps you a little http://nemops.com/prestashop-product-rating-product-list/ Paul I'm using version 1.5.6 and this guide not to run. Only compatible to 1.5.4.1 and need to do some modification but not how. Have someone is able to adapt the guide to version 1.5.6 or create a module with this information. Thanks Link to comment Share on other sites More sharing options...
nadie Posted October 22, 2013 Share Posted October 22, 2013 I'm using version 1.5.6 and this guide not to run. Only compatible to 1.5.4.1 and need to do some modification but not how. Have someone is able to adapt the guide to version 1.5.6 or create a module with this information. Thanks In Forum Spanish the user Enrique write guide homefeatured.php stars: http://www.prestashop.com/forums/topic/282419-estrellas-de-valoracion-en-destacados-de-la-home/?do=findComment&comment=1428740 Sorry for my English Link to comment Share on other sites More sharing options...
SmartDataSoft Posted October 22, 2013 Share Posted October 22, 2013 We have build one , if I got time I will release this open source , see smartdatasoft.net/prestashop Only a line ok hook code need to put in your tpl after set up the module it work any place of the shop What you like Link to comment Share on other sites More sharing options...
vekia Posted October 22, 2013 Share Posted October 22, 2013 smartdatasoft i tried to check your solution but it's unfortunately under maintenance mode Link to comment Share on other sites More sharing options...
SmartDataSoft Posted October 22, 2013 Share Posted October 22, 2013 I am really sorry for that , I forgot that I never enable the shop , after my developer try to update the shop. I just disable maintenance mode . Vekia , you can check that now Link to comment Share on other sites More sharing options...
