monkata Posted August 25, 2013 Share Posted August 25, 2013 Hi, I have two problems. 1. Problem with module Products comment by Prestashop . I can't install it fro BO. After that I delete and reload by ftp. When I loaded and try to find in BO, I can't find it. My question is: where I can find zip file of this module? 2. I have problem with the title in html code: I mean the following #1086;алетна хартия, хигиенни консумативи How can I fix it and to be more Seo friendly> This is my site www.hygiene.bg I use 1.5.4.1 Link to comment Share on other sites More sharing options...
vekia Posted August 25, 2013 Share Posted August 25, 2013 I have problem with the title in html code: I mean the following Title? where you've got it? latest version of product comments module: Link to comment Share on other sites More sharing options...
monkata Posted August 25, 2013 Author Share Posted August 25, 2013 Title! I mean the title in the source code of the page. view-source:http://www.hygiene.bg/bg/ Thank you for the file. I try to install now. Link to comment Share on other sites More sharing options...
monkata Posted August 25, 2013 Author Share Posted August 25, 2013 The following module(s) were not installed properly: - productcomments : I received this after the installing. Link to comment Share on other sites More sharing options...
vekia Posted August 25, 2013 Share Posted August 25, 2013 really weird because it is latest version of this addon (not modified, just original file from fresh installation) can you remove /modules/productcomments/ directory from your FTP ? then try to upload it once again Link to comment Share on other sites More sharing options...
monkata Posted August 25, 2013 Author Share Posted August 25, 2013 I do it before your file. and load a new with ftp. after that again the same problem Link to comment Share on other sites More sharing options...
vekia Posted August 25, 2013 Share Posted August 25, 2013 can you turn on error reporting in your store? maybe there is something wrong with php scripts, if so - then you will see error message with issue specification (what and where doesnt work) Link to comment Share on other sites More sharing options...
monkata Posted August 25, 2013 Author Share Posted August 25, 2013 How can you turn on error reporting in my store? I read in the forums, but I have in @ini_set('display_errors', 'off') a few. some are one, some of. I don't know, which one. Link to comment Share on other sites More sharing options...
vekia Posted August 25, 2013 Share Posted August 25, 2013 Open the config/defines.inc.php change: /* Debug only */ define('_PS_MODE_DEV_',false); to: /* Debug only */ define('_PS_MODE_DEV_',true); Link to comment Share on other sites More sharing options...
Dolke Posted January 31, 2014 Share Posted January 31, 2014 Removing the folder didn't do the trick as I have the same issue.This is the error: http://prntscr.com/2o7xh9 Link to comment Share on other sites More sharing options...
vekia Posted January 31, 2014 Share Posted January 31, 2014 when you see this error message? Link to comment Share on other sites More sharing options...
Dolke Posted January 31, 2014 Share Posted January 31, 2014 (edited) I'm seeing this when I try to install older version of a module 2.3http://prntscr.com/2o8pve Edited January 31, 2014 by Dolke (see edit history) Link to comment Share on other sites More sharing options...
