Jason LIn Posted August 17, 2013 Share Posted August 17, 2013 (edited) Featured products on the homepage. Define the number of products to be displayed. 12 I change the number of featured products on the homepage,but on the homepage it don't activates. and i add new products, homepage is also show the four products. how to deals the problem? Edited August 17, 2013 by vekia (see edit history) Link to comment Share on other sites More sharing options...
vekia Posted August 17, 2013 Share Posted August 17, 2013 when you change the "number of products to be displayed" in module configuration page, after save - changes appear properly in your bo? i mean that you see new value there? Link to comment Share on other sites More sharing options...
Jason LIn Posted August 17, 2013 Author Share Posted August 17, 2013 when you change the "number of products to be displayed" in module configuration page, after save - changes appear properly in your bo? i mean that you see new value there? Yes,it can work. the number is new number Link to comment Share on other sites More sharing options...
vekia Posted August 17, 2013 Share Posted August 17, 2013 so the question is: you use default theme? Im asking because problem looks like related to the theme Link to comment Share on other sites More sharing options...
Jason LIn Posted August 17, 2013 Author Share Posted August 17, 2013 so the question is: you use default theme? Im asking because problem looks like related to the theme yes,the default theme Link to comment Share on other sites More sharing options...
vekia Posted August 17, 2013 Share Posted August 17, 2013 is there any chance to check your website? if so, please share the url Link to comment Share on other sites More sharing options...
Jason LIn Posted August 17, 2013 Author Share Posted August 17, 2013 is there any chance to check your website? if so, please share the url http://www.snapbackswholesaleus.com/ test online store Link to comment Share on other sites More sharing options...
vekia Posted August 17, 2013 Share Posted August 17, 2013 take a look on your home category: http://www.snapbackswholesaleus.com/2-home you've got only 4 products added to this category. Link to comment Share on other sites More sharing options...
Jason LIn Posted August 17, 2013 Author Share Posted August 17, 2013 take a look on your home category: http://www.snapbacks...leus.com/2-home you've got only 4 products added to this category. how can i added more products to this cartegory, i added the products with csv, and don't knower how to belong to this category,thanks Link to comment Share on other sites More sharing options...
Jason LIn Posted August 17, 2013 Author Share Posted August 17, 2013 i know how to deal with this problem,thanks! Link to comment Share on other sites More sharing options...
vekia Posted August 17, 2013 Share Posted August 17, 2013 you can define product categories in each product edit page, you can define as many associations as you want. your problem is solved? Link to comment Share on other sites More sharing options...
Jason LIn Posted August 17, 2013 Author Share Posted August 17, 2013 you can define product categories in each product edit page, you can define as many associations as you want. your problem is solved? yes,thanks! Link to comment Share on other sites More sharing options...
vekia Posted August 17, 2013 Share Posted August 17, 2013 okay, thanks for confirmation im going to mark this topic as [solved] and im closing it. if you will have any other questions related to the prestashop - feel free to open new topics best regards Link to comment Share on other sites More sharing options...
