Sarak Posted May 22, 2013 Share Posted May 22, 2013 (edited) I wanted to switch a few things around so I started palying about with hooks and positions. Turns out, it wasn't what I wanted after all so I changed everything back to what it was. But I must have missed somehting when putting it right because, since then, the short description on EVERY product page has been pushed so far to the right and I don't know why. I didn't even edit the product.tpl. Here's an example and every product looks like it - http://www.totalfanc...or-costume.html Any ideas as to why this is happening? Thanks! Edited May 23, 2013 by vekia (see edit history) Link to comment Share on other sites More sharing options...
Carolina Custom Designs Posted May 22, 2013 Share Posted May 22, 2013 Can you explain further? The page looks fine to me. What am I missing? Marty Shue Link to comment Share on other sites More sharing options...
yaniv14 Posted May 22, 2013 Share Posted May 22, 2013 You probably need to clear your browser cache (ctrl + f5 - 2 or 3 times). everything looks fine from here. Link to comment Share on other sites More sharing options...
vekia Posted May 22, 2013 Share Posted May 22, 2013 for me the page also looks fine, we are waiting for more informations Link to comment Share on other sites More sharing options...
Sarak Posted May 22, 2013 Author Share Posted May 22, 2013 I've managed to fix the product page problem but now my featured products on the homepage are pushed to the left, as if they are aligned to the left rather than in the center. Changing the "#featured-products_block_center li" width doesn't seem to be helping. The bigger the width, they all end up in a vertical line. The smaller the width, they end up overlapping each other. Link to comment Share on other sites More sharing options...
Sarak Posted May 22, 2013 Author Share Posted May 22, 2013 (edited) I've managed to fix the Featured Products on the homepage by changing the #center_column width in global.css But now the product pages are messed up again.... Edited May 22, 2013 by Sarak (see edit history) Link to comment Share on other sites More sharing options...
Sarak Posted May 22, 2013 Author Share Posted May 22, 2013 I've also just noticed that the subcategories and products in the products lists have all been pushed down to the bottom of the page, whereas they used to sit next to the left column in the center of the page. I wish I'd left it alone now. Really don't know what I did! Link to comment Share on other sites More sharing options...
vekia Posted May 22, 2013 Share Posted May 22, 2013 hey i checked your page, cleared browser cache, and everything looks the same can you prepare a screenshot with your issue? Link to comment Share on other sites More sharing options...
Sarak Posted May 22, 2013 Author Share Posted May 22, 2013 Hey, I've managed to fix it by replacing my header.tpl with the original from the theme I'm using. Basically, I've changed it back to what it used to be and it's all good. Sorry to keep going back and forth. Have been spending the last 3 hours trying to fix it! Link to comment Share on other sites More sharing options...
vekia Posted May 23, 2013 Share Posted May 23, 2013 no problem my friend :-) so, your issue is finally solved? Link to comment Share on other sites More sharing options...
Sarak Posted May 23, 2013 Author Share Posted May 23, 2013 ^ Yes, it seems to be, thanks. Fingers crossed! Link to comment Share on other sites More sharing options...
vekia Posted May 23, 2013 Share Posted May 23, 2013 okay so im going to mark this thread as solved (i will also change the title a bit) regards Link to comment Share on other sites More sharing options...
