help help help : Problém prestashop
Bonjour ,
J'ai travaillé en local sur prestashop , j'ai presque fini ma boutique et puis quand j'ai transféré les fichiers au serveur j'ai eu l'erreur suivant , pourtant en local je n'ai aucun problém
Fatal error: Uncaught exception 'SmartyException' with message 'Plugin "productPrice" not callable' in /home/xxx/public_html/dev2/tools/smarty/sysplugins/smarty_internal_templatebase.php:428 Stack trace: #0 /home/xxx/public_html/dev2/config/smarty.config.inc.php(194): Smarty_Internal_TemplateBase->registerPlugin('function', 'productPrice', Array) #1 /home/xxx/public_html/dev2/config/smarty.config.inc.php(66): smartyRegisterFunction(Object(Smarty), 'function', 'productPrice', Array) #2 /home/xxx/public_html/dev2/config/config.inc.php(152): require_once('/home/xxx/pu...') #3 /home/xxx/public_html/dev2/index.php(28): require('/home/xxx/pu...') #4 {main} thrown in /home/xxx/public_html/dev2/tools/smarty/sysplugins/smarty_internal_templatebase.php on line 428
Edited by debutante-en-presta (see edit history)
Thank you , ill put it in english too :)
i created a store on prestashop 1.4.9, in the first i worked in the localhost , and all is right , but when i sent the files to the server , i found this error :
