nguyentrunghoa Posted October 10, 2012 Share Posted October 10, 2012 Hi everyone, I have a problem with my Xampserver configuration. I am developing a site with Prestashop, when I go to the translation page I receive this warning: "Warning, your PHP configuration limits the maximum number of fields to post in a form: 1000 for max_input_vars. Please ask your hosting provider to increase the this limit to 4501 at least or edit the translation file manually." How can I solve above the problem? Thank you very much! Link to comment Share on other sites More sharing options...
vekia Posted October 10, 2012 Share Posted October 10, 2012 (edited) you must change some parameters in PHP configuration. You've got server on LINUX or windows? Edited October 10, 2012 by vekia (see edit history) Link to comment Share on other sites More sharing options...
nguyentrunghoa Posted October 10, 2012 Author Share Posted October 10, 2012 Thanks! I'm using localhost on Windows Vista 64. I'm not a technician IT, so don know how to configuration. Please tell me how to do? Thanks again! Link to comment Share on other sites More sharing options...
vekia Posted October 10, 2012 Share Posted October 10, 2012 (edited) Thanks! I'm using localhost on Windows Vista 64. I'm not a technician IT, so don know how to configuration. Please tell me how to do? Thanks again! ok, so you must: 1) go to directory where you installed xampp 2) open php directory 3) find php.ini file and open it 4) now you must edit line: max_input_vars = 1000 set higher value of this variable. 5) save php.ini file 6) restart your xampp server if it helps, add to the title of topic [sOLVED] Edited October 10, 2012 by vekia (see edit history) 3 Link to comment Share on other sites More sharing options...
nguyentrunghoa Posted October 10, 2012 Author Share Posted October 10, 2012 Thanks for your help! before I did the same you tell, but it was not ok and still has above problem! I don't know how to solve? Link to comment Share on other sites More sharing options...
vekia Posted October 10, 2012 Share Posted October 10, 2012 You've removed semicolon? YOu've got there ;max_input_vars or only max_input_vars? it's important to remove semicolon. If semicolon exists there, variable is set to default, which mean 1000 solution: Search for 'max_input_vars', uncomment it (remove the semicolon), and set it to 3000('max_input_vars = 3000'). 1 Link to comment Share on other sites More sharing options...
vekia Posted October 10, 2012 Share Posted October 10, 2012 my solution writed above works with PHP in version 5.3.9+ if it doesn't work for you you can add in prestashop backoffice (tools->generators / htaccess file generation) this line: php_value max_input_vars 6000 2 Link to comment Share on other sites More sharing options...
nguyentrunghoa Posted October 10, 2012 Author Share Posted October 10, 2012 I tried 2 method: max_input_vars and ;max_input_vars. but It is not ok! I'm using PrestaShop V1.5.1.0, I can't find Menu Tools > Generators htacess file. Please tell me how to find Generators htacess file in prestashop backoffice? My Infor: Server information Server information: Windows NT build 6001 (Windows Vista Home Premium Edition Service Pack 1) i586 Server software version: Apache/2.4.3 (Win32) OpenSSL/1.0.1c PHP/5.4.7 PHP version: 5.4.7 Memory limit: 128M Max execution time: 30 Database information MySQL version: 5.5.27 MySQL engine: InnoDB Tables prefix: ps_ Store information Prestashop version: 1.5.1.0 Shop URL: http://localhost/prestashop/ Current theme in use: default Link to comment Share on other sites More sharing options...
Hobbes Posted October 10, 2012 Share Posted October 10, 2012 I am on 1.4.9.0 and tried to generate .htaccess as you said but i got a big error on the site "Unable to connect". I had therefore to recover a saved .htaccess in order to make the site run again. Link to comment Share on other sites More sharing options...
vekia Posted October 10, 2012 Share Posted October 10, 2012 hmmm so there is something wrong, in my local everything goes ok ... Link to comment Share on other sites More sharing options...
nguyentrunghoa Posted October 10, 2012 Author Share Posted October 10, 2012 hmmm so there is something wrong, in my local everything goes ok ... What are you using: - Prestashop version? - Xampp Version; Wampp; appserv...? - OS? (XP; Vista 32, 64; Win 7 32, 64) Link to comment Share on other sites More sharing options...
Mura82 Posted October 10, 2012 Share Posted October 10, 2012 I open a ticket to my host provider, and they change the value from 1.000 to 10.000. Now work perfectly. Link to comment Share on other sites More sharing options...
nguyentrunghoa Posted October 10, 2012 Author Share Posted October 10, 2012 I open a ticket to my host provider, and they change the value from 1.000 to 10.000. Now work perfectly. How to solve my problem? Link to comment Share on other sites More sharing options...
benjamin utterback Posted October 10, 2012 Share Posted October 10, 2012 Hello, nguyen, you can force the generation of a new htaccess file from your 1.5.1 backoffice by simply turning off and on your Friendly URL option. It is a good idea to clear the cookies and cache when you do this. Link to comment Share on other sites More sharing options...
nguyentrunghoa Posted October 10, 2012 Author Share Posted October 10, 2012 Hello, nguyen, you can force the generation of a new htaccess file from your 1.5.1 backoffice by simply turning off and on your Friendly URL option. It is a good idea to clear the cookies and cache when you do this. Excuseme! I'm not IT technician, so I don't know how to do as you talk! Please tell me more! Thank so much! Link to comment Share on other sites More sharing options...
benjamin utterback Posted October 10, 2012 Share Posted October 10, 2012 Hello ngueyen, First, you should create and confirm a working back up of your store. In PrestaShop 1.5.1 in your Back Office, please navigate to Preferences/ SEO and URL scroll down until you see a Friendly URL option and toggle that function to force a regeneration of the htaccess code. To Clear the smarty cache - go to cache/smarty and delete files in both folders (do not delete index.php) To learn about how to clear the cookies from different browsers, you can read this link Link to comment Share on other sites More sharing options...
Mura82 Posted October 10, 2012 Share Posted October 10, 2012 How to solve my problem? Whops... I hadn't read that you are working on localhost Link to comment Share on other sites More sharing options...
nguyentrunghoa Posted October 11, 2012 Author Share Posted October 11, 2012 Hello ngueyen, First, you should create and confirm a working back up of your store. In PrestaShop 1.5.1 in your Back Office, please navigate to Preferences/ SEO and URL scroll down until you see a Friendly URL option and toggle that function to force a regeneration of the htaccess code. To Clear the smarty cache - go to cache/smarty and delete files in both folders (do not delete index.php) To learn about how to clear the cookies from different browsers, you can read this link Thank you! My problem is solved! Link to comment Share on other sites More sharing options...
Hobbes Posted October 11, 2012 Share Posted October 11, 2012 In local, there are no problems as i can change the max_input_vars by myself. But online, the server i use doesn't allow the change of this value. The unique solution is to change in local mode the files then to send them online. Link to comment Share on other sites More sharing options...
vekia Posted October 11, 2012 Share Posted October 11, 2012 In local, there are no problems as i can change the max_input_vars by myself. But online, the server i use doesn't allow the change of this value. The unique solution is to change in local mode the files then to send them online. You can always ask your provider if he could change the value of this parameter Link to comment Share on other sites More sharing options...
Hobbes Posted October 11, 2012 Share Posted October 11, 2012 You can always ask your provider if he could change the value of this parameter This is what i did and answer (my provider is OVH) was "not possible on this plan. You need a VPS server". Link to comment Share on other sites More sharing options...
benjamin utterback Posted October 11, 2012 Share Posted October 11, 2012 Hello hobbes, that is very strange that they would say this to you. PresatShop doesnot take enough space or memory for you to require a VPS, I suggest you take a look at www.bluehost.com/prestashop . You will not need a vps and overall BlueHost has great configuration and compatibility/speed with PrestaShop Link to comment Share on other sites More sharing options...
vekia Posted October 12, 2012 Share Posted October 12, 2012 Hello hobbes, that is very strange that they would say this to you. PresatShop doesnot take enough space or memory for you to require a VPS, I suggest you take a look at www.bluehost.com/prestashop . You will not need a vps and overall BlueHost has great configuration and compatibility/speed with PrestaShop my clients have used the services of OVH, but gave up a long time ago, mainly due to poor support. Some of them just moved to Bluehost and I must admit that it is much better! Link to comment Share on other sites More sharing options...
smartsd Posted October 15, 2012 Share Posted October 15, 2012 Hi, can anyone help me! i have the same problem... i use prestashop 1.5.2 & MAMP i cannot change it.... already done like Benjamin Utterback says but i cannot do this step : "To Clear the smarty cache - go to cache/smarty and delete files in both folders (do not delete index.php)" Or If you know how to change the .htaccess great .... Or Where i can change the php.ini on MAMP Many Thanks.. Link to comment Share on other sites More sharing options...
Hobbes Posted October 16, 2012 Share Posted October 16, 2012 Well, i'm on a mutualized plan and the config is the same for everybody. For the Bluehost, i don't know them but it seems their servers are only in US. I prefer a provider located in France for better comfort and speed. Link to comment Share on other sites More sharing options...
Mura82 Posted October 16, 2012 Share Posted October 16, 2012 This is what i did and answer (my provider is OVH) was "not possible on this plan. You need a VPS server". My provider is maybe the worst in Italy and they don't allow any edit to php.ini for the shared hosts, but when I asked them to modify JUST that string, they did it with no problem. Try to ask them again very gently and just for max_imput_vars Link to comment Share on other sites More sharing options...
benjamin utterback Posted October 16, 2012 Share Posted October 16, 2012 Hello all, it is certainly strange that OVH is suggesting a VPS, it could be a low level VPS, that seems like an extreme case. Hobbes, I will ask my team for a recommended Hosting Provider that will work for you. You can also use Mura82's suggestion to simply ask again, maybe another representative will help you. Link to comment Share on other sites More sharing options...
vekia Posted October 16, 2012 Share Posted October 16, 2012 Hello all, it is certainly strange that OVH is suggesting a VPS, it could be a low level VPS, that seems like an extreme case. Hobbes, I will ask my team for a recommended Hosting Provider that will work for you. You can also use Mura82's suggestion to simply ask again, maybe another representative will help you. Hi benjamin Maybe good thing is also to update prestashop source. I mean that issue with "max_input_vars" occur only in translation feature. It's because when we want to translate ONE module, we go to the translation page where other module is loaded too. Maybe good thing is a feature, where we can translate only ONE module, not all. simple solution, and make the whole process will be faster 1 Link to comment Share on other sites More sharing options...
benjamin utterback Posted October 16, 2012 Share Posted October 16, 2012 Hello vekia, thank you for the suggestion. I will discuss this with my team and see if we can implement this in upcoming versions. Thanks for all the support and Hobbes, I will get back with you shortly with a recommendation in the meantime. Link to comment Share on other sites More sharing options...
henrymonk Posted October 16, 2012 Share Posted October 16, 2012 my solution writed above works with PHP in version 5.3.9+ if it doesn't work for you you can add in prestashop backoffice (tools->generators / htaccess file generation) this line: php_value max_input_vars 6000 for me this works thank you Link to comment Share on other sites More sharing options...
timeatop Posted October 23, 2012 Share Posted October 23, 2012 (edited) And ft the provider does not want to increase this value? Edited October 23, 2012 by timeatop (see edit history) Link to comment Share on other sites More sharing options...
benjamin utterback Posted October 23, 2012 Share Posted October 23, 2012 Hello timeatop, your hosting provider does not want to increase this value? Why not? Link to comment Share on other sites More sharing options...
Saras B. Posted September 19, 2013 Share Posted September 19, 2013 Sometimes php.ini won't allow to edit by your hosting provider and .htaccess won't work, i've used .user.ini, it helped me to solve this max_input_vars problem, just created in directory where is prestashop installed file named .user.ini and put there code max_input_vars = xxxx (where xxxx your desired number of lines how much you needed 1000, 2000, 3000 etc.). 1 Link to comment Share on other sites More sharing options...
cat1999 Posted April 23, 2014 Share Posted April 23, 2014 Sometimes php.ini won't allow to edit by your hosting provider and .htaccess won't work, i've used .user.ini, it helped me to solve this max_input_vars problem, just created in directory where is prestashop installed file named .user.ini and put there code max_input_vars = xxxx (where xxxx your desired number of lines how much you needed 1000, 2000, 3000 etc.). Perfect this worked for me too! Thx 1 Link to comment Share on other sites More sharing options...
ericleonardocunha Posted May 7, 2014 Share Posted May 7, 2014 I found my PHP.ini at /usr/lib Running on Centos 6.5. So put max_input_vars = 10000 and gave all right. Solved. Link to comment Share on other sites More sharing options...
AleChap73 Posted November 2, 2014 Share Posted November 2, 2014 Hi I've this error message: Attenzione! La tua configurazione PHP limita il numero di campi dei post nel form 1000 per max_input_vars.Per favore chiedi al tuo provider di aumentare questo limite ad 1404 almeno, o si dovranno modificare i file di traduzione. I use xampp for MAC Can you help me?ThanksAlessandro Link to comment Share on other sites More sharing options...
vekia Posted November 3, 2014 Share Posted November 3, 2014 Hi I've this error message: Attenzione! La tua configurazione PHP limita il numero di campi dei post nel form 1000 per max_input_vars. Per favore chiedi al tuo provider di aumentare questo limite ad 1404 almeno, o si dovranno modificare i file di traduzione. I use xampp for MAC Can you help me? Thanks Alessandro you have to increase max input vars param of php settings: have you tried solutions mentioned before ? (first page of this thread) Link to comment Share on other sites More sharing options...
Joao_azores Posted September 4, 2015 Share Posted September 4, 2015 Hello, My hosting company is SIMPLEHELIX. Success when inserting this in my .htacess file "php_value max_input_vars 10000" Thank you! Link to comment Share on other sites More sharing options...
