Products do not display in topseller/new products block
Hi,
I have been able to sort out the issue with "New Product" display by setting the "Number of days product is considered new" under preferences -> Products.
But still not able to sort out the "Top Seller" block products display.
Hi cpcs,
If you've just enabled the Top Sellers block, it will not have any content to display. It does not gather that data when the module is disabled. Give it a day or two though, and you should start to see it getting populated based on your customers' purchases.
I hope this helps.
-Mike
