[SOLVED] No more contents, body, products, footer
Hi All,
Im a new Prestashop user and I thank you guys for this forum because its helps me a lot.
I'm working on Prestashop 1.4.7.3 on Mac and I dont have the initial prestashop theme.
My website was working perfectly until I deleted blocklanguages in order to install blocklanguagesDP (with a menu list)
I changed my mind and I installed back the initial languages module.
Since this operation, i don't have the contents anymore (no CMS, no body, no footer, no products...)
Could you please help me to fix this ?
Thanks
Kwij
www.flexsuit.com
Edited by kwij (see edit history)
Thank you.
In the source code, I found the following errors/things:
1/
<b>Warning</b>: asort() expects parameter 1 to be array, boolean given in <b>/homez.501/flexsuit/www/modules/tmspecials/tmspecials.php</b> on line <b>57</b><br
2/
b>Notice</b>: Undefined index: id_cms in <b>/homez.501/flexsuit/www/tools/smarty/compile/c61af010bd2331e2121eda96c0b92da99c5b31d8.file.tmheaderlinks.tpl.php</b> on line <b>29</
3/
<b>Warning</b>: include_once(/homez.501/flexsuit/www/modules//locationdetection/locationdetection.php) [<a href='function.include-once'>function.include-once</a>]: failed to open stream: No such file or directory in <b>/homez.501/flexsuit/www/override/classes/FrontController.php</b> on line <b>32</b><br />
<br />
<b>Warning</b>: include_once() [<a href='function.include'>function.include</a>]: Failed opening '/homez.501/flexsuit/www/modules//locationdetection/locationdetection.php' for inclusion (include_path='.:/usr/local/lib/php') in <b>/homez.501/flexsuit/www/override/classes/FrontController.php</b> on line <b>32</b><br />
<br />
<b>Fatal error</b>: Class 'LocationDetection' not found in <b>/homez.501/flexsuit/www/override/classes/FrontController.php</b> on line <b>33</b><br />
I installed recently location detection module, and I copy and paste the file FrontController.php to www/override/classes.
Moreover, I cannot find anymore location detection in the module in the back office.
What should I do to fix it ?
Thank you for your help :rolleyes:
Thank you tomerg3
I deleted the Frontontrollers file and installed again the module, now it works. :D
Before putting solved in the title, can you help me for the first bug please :
1/
In tmspecials.php line 57 I have :
$tmp = Product::getPricesDrop(intval($params['cookie']->id_lang));
asort($tmp);
if (!$special = Product::getPricesDrop((int)($params['cookie']->id_lang)) AND !Configuration::get
Thank you for your help again.
I am not familiar with that module, you should ask the developer who created it.
It should not stop your page from loading though, and you can turn off error reporting and you will not see it anymore.
