HELP HELP HELP! -->Cart Block expanded as standard!
I would like my cart block to be set as expanded as standard currently with the theme I am using it isnt, what do I need to change to make this happen? Here is the .tpl code:
* 2007-2011 PrestaShop
* NOTICE OF LICENSE
* This source file is subject to the Academic Free License (AFL 3.0)
* that is bundled with this package in the file LICENSE.txt.
* It is also available through the world-wide-web at this URL:
* http://opensource.or...ses/afl-3.0.php
* If you did not receive a copy of the license and are unable to
* obtain it through the world-wide-web, please send an email
* to [email protected] so we can send you a copy immediately.
* DISCLAIMER
* Do not edit or add to this file if you wish to upgrade PrestaShop to newer
* versions in the future. If you wish to customize PrestaShop for your
* needs please refer to http://www.prestashop.com for more information.
* @author PrestaShop SA <[email protected]>
* @copyright 2007-2011 PrestaShop SA
* @version Release: $Revision: 1.4 $
* @license http://opensource.or...ses/afl-3.0.php Academic Free License (AFL 3.0)
* International Registered Trademark & Property of PrestaShop SA
{* IMPORTANT : If you change some data here, you have to report these changes in the ./blockcart-json.js (to let ajaxCart available) *}
{if $ajax_allowed}
<script type="text/javascript">
var CUSTOMIZE_TEXTFIELD = {$CUSTOMIZE_TEXTFIELD};
var customizationIdMessage = '{l s='Customization #' mod='blockcart' js=1}';
var removingLinkText = '{l s='remove this product from my cart' mod='blockcart' js=1}';
</script>
{/if}
<!-- MODULE Block cart -->
<div id="cart_block" class="block exclusive">
<h4>
<a href="{$link->getPageLink("$order_process.php", true)}">{l s='Shopping Cart' mod='blockcart'}</a>
{if $ajax_allowed}
<span id="block_cart_expand" {if isset($colapseExpandStatus) && $colapseExpandStatus eq 'expanded'}class="hidden"{/if}> </span>
<span id="block_cart_collapse" {if isset($colapseExpandStatus) && $colapseExpandStatus eq 'collapsed' || !isset($colapseExpandStatus)}class="hidden"{/if}> </span>
{/if}
</h4>
<div class="block_content">
<!-- block summary -->
<div id="cart_block_summary" class="{if isset($colapseExpandStatus) && $colapseExpandStatus eq 'expanded' || !$ajax_allowed}collapsed{else}expanded{/if}">
<span class="ajax_cart_quantity" {if $cart_qties <= 0}style="display:none;"{/if}>{$cart_qties}</span>
<span class="ajax_cart_product_txt_s" {if $cart_qties <= 1}style="display:none"{/if}>{l s='products' mod='blockcart'}</span>
<span class="ajax_cart_product_txt" {if $cart_qties > 1}style="display:none"{/if}>{l s='product' mod='blockcart'}</span>
<span class="ajax_cart_total" {if $cart_qties <= 0}style="display:none"{/if}>{if $priceDisplay == 1}{convertPrice price=$cart->getOrderTotal(false)}{else}{convertPrice price=$cart->getOrderTotal(true)}{/if}</span>
<span class="ajax_cart_no_product" {if $cart_qties != 0}style="display:none"{/if}>{l s='(empty)' mod='blockcart'}</span>
</div>
<!-- block list of products -->
<div id="cart_block_list" class="{if isset($colapseExpandStatus) && $colapseExpandStatus eq 'expanded' || !$ajax_allowed}expanded{else}collapsed{/if}">
{if $products}
<dl class="products">
{foreach from=$products item='product' name='myLoop'}
{assign var='productId' value=$product.id_product}
{assign var='productAttributeId' value=$product.id_product_attribute}
<dt id="cart_block_product_{$product.id_product}{if $product.id_product_attribute}_{$product.id_product_attribute}{/if}" class="{if $smarty.foreach.myLoop.first}first_item{elseif $smarty.foreach.myLoop.last}last_item{else}item{/if}">
<span class="quantity-formated"><span class="quantity">{$product.cart_quantity}</span>x</span>
<a class="cart_block_product_name" href="{$link->getProductLink($product.id_product, $product.link_rewrite, $product.category)}" title="{$product.name|escape:html:'UTF-8'}">{t text=$product.name length='20' encode='true'}</a>
<span class="remove_link">{if !isset($customizedDatas.$productId.$productAttributeId)}<a rel="nofollow" class="ajax_cart_block_remove_link" href="{$link->getPageLink('cart.php')}?delete&id_product={$product.id_product}&ipa={$product.id_product_attribute}&token={$static_token}" title="{l s='remove this product from my cart' mod='blockcart'}"> </a>{/if}</span>
<span class="price">{if $priceDisplay == $smarty.const.PS_TAX_EXC}{displayWtPrice p="`$product.total`"}{else}{displayWtPrice p="`$product.total_wt`"}{/if}</span>
</dt>
{/foreach}
</dl>
{/if}
<p {if $products}class="hidden"{/if} id="cart_block_no_products">{l s='No products' mod='blockcart'}</p>
{if $discounts|@count > 0}<table id="vouchers">
<tbody>
{foreach from=$discounts item=discount}
<tr class="bloc_cart_voucher" id="bloc_cart_voucher_{$discount.id_discount}">
<td class="name" title="{$discount.description}">{$discount.name|cat:' : '|cat:$discount.description|truncate:18:'...'|escape:'htmlall':'UTF-8'}</td>
<td class="price">-{if $discount.value_real != '!'}{if $priceDisplay == 1}{convertPrice price=$discount.value_tax_exc}{else}{convertPrice price=$discount.value_real}{/if}{/if}</td>
<td class="delete"><a href="{$link->getPageLink("$order_process.php", true)}?deleteDiscount={$discount.id_discount}" title="{l s='Delete'}"><img src="{$img_dir}icon/delete.gif" alt="{l s='Delete'}" width="11" height="13" class="icon" /></a></td>
</tr>
{/foreach}
</tbody>
</table>
{/if}
<div id="cart-prices">
<p>
<span>{l s='Shipping' mod='blockcart'}</span>
<span id="cart_block_shipping_cost" class="price ajax_cart_shipping_cost">{$shipping_cost}</span>
<br/>
{if $show_wrapping}
{assign var='blockcart_cart_flag' value='Cart::ONLY_WRAPPING'|constant}
<span>{l s='Wrapping' mod='blockcart'}</span>
<span id="cart_block_wrapping_cost" class="price cart_block_wrapping_cost">{if $priceDisplay == 1}{convertPrice price=$cart->getOrderTotal(false, $blockcart_cart_flag)}{else}{convertPrice price=$cart->getOrderTotal(true, $blockcart_cart_flag)}{/if}</span>
<br/>
{/if}
</p>
<p class="total">
{if $show_tax && isset($tax_cost)}
<span>{l s='Tax' mod='blockcart'}</span>
<span id="cart_block_tax_cost" class="price ajax_cart_tax_cost">{$tax_cost}</span>
<br/>
{/if}
<span>{l s='Total' mod='blockcart'}</span>
<span id="cart_block_total" class="price ajax_block_cart_total">{$total}</span>
</p>
</div>
<p id="cart-buttons">
{if $order_process == 'order'}<a href="{$link->getPageLink("$order_process.php", true)}" class="button_small" title="{l s='Cart' mod='blockcart'}">{l s='Cart' mod='blockcart'}</a>{/if}
<a href="{$link->getPageLink("$order_process.php", true)}{if $order_process == 'order'}?step=1{/if}" id="button_order_cart" class="exclusive{if $order_process == 'order-opc'}_large{/if}" title="{l s='Check out' mod='blockcart'}">{l s='Check out' mod='blockcart'}</a>
</p>
</div>
</div>
</div>
<!-- /MODULE Block cart -->
Thanks,
Rob
Just try going through the file and comment out one line at a time that refers to expand or collapse until you get the desired effect.
Like This.
<!-- <span id="block_cart_collapse" {if isset($colapseExpandStatus) && $colapseExpandStatus eq 'collapsed' || !isset($colapseExpandStatus)}class="hidden"{/if}> </span> -->
Ok this should work, go to ..../ modules/ blockcart/ and edot blockcart.tpl look at line 37 or find the line below.
<div id="cart_block_list" class="{if isset($colapseExpandStatus) && $colapseExpandStatus eq 'expanded' || !$ajax_allowed || !isset($colapseExpandStatus)}expanded{else}collapsed{/if}">
Change to
<div id="cart_block_list" class="{if isset($colapseExpandStatus) && $colapseExpandStatus eq 'expanded' || !$ajax_allowed || !isset($colapseExpandStatus)}expanded{/if}">
This forces the box open but the collapse expand buttons no longer work.
You can remove the buttons by deleting these two lines from blockcart.css
#cart_block h4 span#block_cart_collapse { background-image: url('../../../img/icon/sort_asc_white.png') }
#cart_block h4 span#block_cart_expand { background-image: url('../../../img/icon/sort_desc_white.png') }
That is the best I can offer.
