[Solved] Huge problem when downloading products of more than 50MB
Hi!
This is a new problem for me. We have a site which is an ecommerce based on paid downloads.
When users pay and download files less than 50MB large there's no problem.
But, when they try to download a file which is more than 50MB, the file they get is just 189kb.
We checked the programming, and the server config and we couldn't find the problem.
I'd be very grateful if somebody could help me.
Thanks a lot in advance!
Hi,
This could be a restriction from your hosting provider, you should get in touch with them and let them know what is going on, they may be able to help or you may need to upgrade your hosting package.
Have you tried compressing the files?
Best regards,
Tim
Hi Tim! They're already zipped.
We tried to upgrade the hosting package, but it didn't work.
I think that we can just try to buy a dedicated host, but it's quite expensive for us.
Thanks! :)
You can still find out by using phpinfo()..... If you're on a shared host, most likely it's 64MB.
I think there may be a thread in the forum on how to modify the file download so it doesn't take so much RAM, but I don't know for sure.
