in4apps Posted December 13, 2023 Share Posted December 13, 2023 Hello, I have a question about how to approach the stock management of products that are made up of other products. Maybe it is a concept that cannot be automated, but I don't know it. In order to have everything under control, I would like to create a normal white t-shirt product, another product that is ink with drawing x, and another with ink with drawing z. These products would be invisible in my shop. These products would be invisible in my shop. Then I want to create a visible product, which is the white t-shirt with drawing x, but also another one which is a white t-shirt with drawing z. In the end what I have is a fairly large list of different products, but which are actually much less, only that they are common between them. And what I am interested in is to keep track of those primary products that make up the complex product formed by several simple ones. Is it possible to do this either with the prestashop stock system itself or with some module? thank you Link to comment Share on other sites More sharing options...
