martyn137 Posted May 20, 2021 Share Posted May 20, 2021 Viewed products and Products of the same category modules, the price and name of the item are displayed only for the first product. The next tiles are just a photo. Before the file modifications on the ftp server it was ok. What could be the cause? presta 1.7.7.3 warehouse store template Regards Link to comment Share on other sites More sharing options...
David MEYER Posted March 1, 2022 Share Posted March 1, 2022 Hello, I hope you already have a soluce, but for others, change the renderWidget function, for not using cache, and it's ok : public function renderWidget($hookName = null, array $configuration = []) { if (isset($configuration['product']['id_product'])) { $this->currentProductId = $configuration['product']['id_product']; } if ('displayProductAdditionalInfo' === $hookName) { $this->addViewedProduct($this->currentProductId); return; } if (!isset($this->context->cookie->viewed) || empty($this->context->cookie->viewed)) { return; } $variables = $this->getWidgetVariables($hookName, $configuration); if (empty($variables)) { return false; } $this->smarty->assign($variables); return $this->fetch($this->templateFile); } 1 Link to comment Share on other sites More sharing options...
martyn137 Posted March 1, 2022 Author Share Posted March 1, 2022 It works. Thank you very much. Link to comment Share on other sites More sharing options...
